11 years agoDE1-SoC : change USB3300 PHY host mode to peripheral mode! How To??
Hi, I'm using DE1-SoC board with linux console provided by Terasic. what should i do to change the USB Host mode to USB peripheral mode ? I know that i have to short the ID pin of usb3300 PHY...
11 years agoHello,
According to me, due to present schematic of DE1-SOC ( cyclone V ) kit, you would not be able to run it in device mode. It is intended to work in host mode only.Although Cyclone V Soc has OTG IP core in it, on hardware it is connected to USB Hub. So it would not be possible unless you make any change in board. also making changes in board is not recommended. So I think you should look for other board (perhaps DE0- nano which you mentioned earlier ) which has micro AB connector to support both Host and device functionality. Hope it would help. Cheers, Bhaumik
