11 years agoDE1-SoC : change USB3300 PHY host mode to peripheral mode! How To??
Hi, I'm using DE1-SoC board with linux console provided by Terasic. what should i do to change the USB Host mode to USB peripheral mode ? I know that i have to short the ID pin of usb3300 PHY...
11 years agoHello,
I am sorry for delay in response. Here are comments from our side. (1) According to me, you should not make any change in development board. Because in this case, I do not think it would help. See attached image - De1_Soc_USB.png. (2) For Device mode, ID pin status should be 1 ( HIGH ). You can connect it to VDD or you can keep it left floated. ID pin has internal weak pull up resistor.Refer USB3300 datasheet. So if you will not connect it, it will automatically detected as high. (3) Sorry I do not have idea about that. Let us know if you have any doubt. Cheers, Bhaumik
