11 years agoDE1-SoC : change USB3300 PHY host mode to peripheral mode! How To??
Hi, I'm using DE1-SoC board with linux console provided by Terasic. what should i do to change the USB Host mode to USB peripheral mode ? I know that i have to short the ID pin of usb3300 PHY...
11 years agoHI,
First thank you very much for your answer. you are right. I have three question! First: Should i replace the USB connector by a USB micro AB connector and then connect the ID pin to the pin 5 of the mini B connector ?? ( I found this in the user manual of Terasic's new board DE0-nano SoC ). This work is for the OTG mode, The PHY can operate in Host or Device modes. As you can see here http://www.alteraforum.com/forum/attachment.php?attachmentid=10786&stc=1 Second :If it is not necessary ( I just want my board acts as device mode )! Do you think if I do what you said without modifying the USB connector! Is it going to work? ( I read in the technical datasheet of the USB3300 that i have to short USB3300 PHY 's ID pin to V3.3 ... )As you can see here http://www.alteraforum.com/forum/attachment.php?attachmentid=10784&stc=1 But then i was a confused about that pin. Because in the same technical datasheet i found that for peripheral mode ID pin is not shorted... http://www.alteraforum.com/forum/attachment.php?attachmentid=10785&stc=1 Three : What about the software? do you think that i have to modify something in the linux console( provided by Terasic for DE1-SoC) kernel modules?? Thank you!
