11 years agoDE1-SoC : change USB3300 PHY host mode to peripheral mode! How To??
Hi, I'm using DE1-SoC board with linux console provided by Terasic. what should i do to change the USB Host mode to USB peripheral mode ? I know that i have to short the ID pin of usb3300 PHY...
11 years agoHello,
I afraid you MAY not be able to do this. Please see schematic of DE1-SoC. D+/D- pins of on board USB3300 PHY have been connected to USB Hub. To make USB3300 work in device mode, you need to bring D+/D- pins of USB3300 to USB connector. Then you can connect it to your PC via USB cable. I hope this helps to some extent. Let me know if there is any confusion. Cheers, Bhaumik
