15 years agoDE0 Nios II EPCS boot
I am having problems using the flash programmer to load my .sof and .elf files onto the EPCS4 chip of my Terasic DE0 dev board (Cyclone III). My SOPC has an EPCS controller and the reset address of t...
11 years agoHi crts1973,
Have you solved the problem? Recently, I got the same mistake. I have successfully used the flash programmer to load my .sof and .elf files onto my epcs64 chip with Nios II SBT. I used Cyclone IVE EP4CE6F1717. My SOPC builder has SRAM,EPCS controller, sysID,JTAG,PLL,CPU,pio_led.I have set the reset vector to the EPCS controller,exception vetor to SRAM. The question is when I used the niosII command shell order :nios2-flash-programmer --base=0x00000000 \--epcs hello_world.flash There is an error:No EPCS registers found: tried looking at address 0x0000100, 0x00000200, 0x00000300 and 0x00000400 I have tried ensuring the jtag_debug_module_reset output from theNios II Processoris connected to the EPCS Serial Flash Controller reset input, but donnot work! Can you give me some help? Thanks ! Sincerely Luke.
