12 years agoDE0 Nano with SDRAM and EPCS not loading firmware
I have configured the DE0 Nano with a SDRAM, EPCS, and ALTPLL combo that phase shift the SDRAM clock -3ns as required. When I use the flash programmer it completes flashing successfully, restarting t...
12 years agoOk, I understand why nothing was running now. In Qsys for the CPU I had set the SDRAM as the location to start execution but I never copied the application to that starting location. I assumed once I set the SDRAM as the start location the EPCS would automatically know to load into the SDRAM.
If I modify the bootloader to load directly into SDRAM then I would not need to use on-chip memory.
