9 years agoDE0-nano-SoC - Is it possible to reconfigure it at run-time?
Hi all, as the title says, I would like to know that before buying. Thanks!
9 years agoSo I've found this in the manual:
--- Quote Start --- If developers wish to configure FPGA from an application software running on Linux, the MSEL[4:0]needs to be setto “01010”before the programming process begins. If developers using the "Linux Console with frame buffer" or "Linux LXDE Desktop" SD Card image, the MSEL[4:0]needs to be set to “00000” before the board is powered on. --- Quote End --- So basically the first option is what I want and the second one is the standard download the bitstream from PC? Is therefore missing the possibility to configure the FPGA from Quartus?
