10 years agoDE0-Nano Project
Hi, I am a newbie to the DE0-Nano but I have a project in mind and I was wondering if I could get some high level feedback on whether I am on the right track or not. background: I am a so...
10 years agoHello,
This is interesting. Following is what I am understanding from your post. When you connect your DE0-nano to your computer via USB interface, your computer should recognize that as a USB device capable to send some images to it. When you press any push button, some data captured from your sensor should be passed to your computer via USB interface. Is this correct? I have some confusion in following points: --- Quote Start --- when I push one of the push buttons on the DE0-Nano that it will send and resend an image out to the USB. --- Quote End --- What does send and resend mean here? --- Quote Start --- That way I can emulate the entire process and the actual sensor wouldn't need to be used. --- Quote End --- Why do you not need actual sensor? You need to have some data to be sent to your computer via USB. Without sensor, from where will you get data? Regards, Bhaumik
