11 years agoDE0-Nano NIOSII fails to compile due to license issues using free web version
In working through the demonstration applications, specifically the NIOS II processor (my first NIOS II processor), it seems as if I can not successfully compile the system. This is on a NE0-Na...
11 years agoResolved by myself. Evidently there is an option in the EDA Tool settings that you need to turn off in the Simulation to set to "None" so the compiler doesn't attempt to get to the source code.
After changing this I get no errors. Nothing to do with licensing, unless you need to simulate and get into the actual IP.
