10 years agoDE0-Nano Nios II won't boot from EPCS if Compression is Enabled
Hi all, I want to use the EPCS on the DE0-Nano board to configure the FPGA and boot Nios II from it. I am using Quartus Prime 15.1. I found that if I enable compression for the sof file when generati...
10 years agoI have finally solved the problem. By changing to Windows 7 and Qusrtus 13.1. Thanks Altera!!!
