10 years agoDE0-Nano Nios II won't boot from EPCS if Compression is Enabled
Hi all, I want to use the EPCS on the DE0-Nano board to configure the FPGA and boot Nios II from it. I am using Quartus Prime 15.1. I found that if I enable compression for the sof file when generati...
10 years agoThank you very much yflyf
Your document has the following step 8 - 10 that isn't described in ftp://ftp.altera.com/up/pub/altera_material/15.0/tutorials/de0-nano/using_de0-nano_flash.pdf. 8. Click the “Add Hex Data” button 9. Select “Relative Addressing” 10. Select your <project>.hex file containing your Nios II software image However, I have tried all of them but still not work :(
