10 years agoDE0-Nano Nios II won't boot from EPCS if Compression is Enabled
Hi all, I want to use the EPCS on the DE0-Nano board to configure the FPGA and boot Nios II from it. I am using Quartus Prime 15.1. I found that if I enable compression for the sof file when generati...
10 years ago --- Quote Start --- Thank you ylfyf According to the document, the method stated there is for the Cyclone V. But FPGA in DE0 Nano is Cyclone IV E. Is it ok to follow the method? --- Quote End --- It's a general method. Only the first two steps apply to V series (and when used with Quartus II 13.0), so you can skip them and start from step 3.
