10 years agoDE0-Nano Nios II won't boot from EPCS if Compression is Enabled
Hi all, I want to use the EPCS on the DE0-Nano board to configure the FPGA and boot Nios II from it. I am using Quartus Prime 15.1. I found that if I enable compression for the sof file when generati...
10 years agoI am doing the same thing with you but for me no matter I compress or not, the software is not boot after reset.
In your case, the software is load if not compress, right? How did you do that? Did you follow this tutorial? ftp://ftp.altera.com/up/pub/altera_material/15.0/tutorials/de0-nano/using_de0-nano_flash.pdf Is there any bugs in the tutorial? I also follow it but not work for me.
