8 years agoDE0-Nano - Quartus Lite 17.1 - Error (209040): Can't access JTAG chain
I am trying to use a DE0-Nano for basic training but I am stuck on the Programming Device task, basically because it fails with the error error (209040): can't access jtag chain Quartus 17.0 Lite edition is running on a Debian system. The DE0-Nano setup has been previously built from the Windows Tool De0-Nano System Builder. To start with I wrote this simple Verilog file:module binout(clock, a, b, OUT);
input clock, a, b;
output reg OUT;
reg cntr;
initial begin
assign cntr = 0;
end
always
@(posedge clock) begin
if(a)
begin
cntr = cntr + 1;
end
else if(b)
begin
cntr = cntr - 1;
end
OUT = cntr;
end
endmodule from which I built a Symbol File (without any error), to include in a basic block design (bdf file). Then, when I choose to program the device, everything seems OK (I attached a screenshot of the Program Device window), but clicking on "Start", the task always return the mentioned error. What could be wrong in my setup ? Thank you in advance. S. https://alteraforum.com/forum/attachment.php?attachmentid=14751&stc=13 Replies
Have you connected the USB blaster?Check the working of usb blaster. Check the following threads which address the problem. http://www.alteraforum.com/forum/showthread.php?t=21942 https://www.alteraforum.com/forum/showthread.php?t=1257 https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03312011_647.html Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
As shown in the attached picture, the device was/it's connected to the computer. I already saw the links you posted, but all of them refer to hardware related problems (seems reasonable but not for a development kit). Last time I tested the De0-Nano was no more than 2 years ago, and it was working properly. Until now, the board has rested in it's case... Regards, Simon - Altera_Forum
1.Probe the TCK signal to ensure it is a clean signal with no overshoot, undershoot,or ringing. For a chain of devices, you should probe each device in the chain as close to the TCK pin as possible. Noise on any of these pins could cause JTAG programming to fail for the entire chain? 2.Check the passive components in power supply path? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
