14 years agoDE0 Nano - Problem using the provided examples
Hi, i just received my DE0 Nano board and I've been trying the examples in the system CD. I've downloaded and installed Quartus 11.0sp1 + Nios II/Nios II GCC4 Toolchain. Every example wo...
12 years ago --- Quote Start --- $'\r': command not found. --- Quote End --- This message is related to the file using Windows encoding instead of Unix. The Cygwin command dos2unix can be used to correct the encoding. I agree that it is pretty lame that the demos do not work "out of the box". Personally, I just start with the schematic of the board and write my own demos. Cheers, Dave
