14 years agoDE0 Nano - Problem using the provided examples
Hi, i just received my DE0 Nano board and I've been trying the examples in the system CD. I've downloaded and installed Quartus 11.0sp1 + Nios II/Nios II GCC4 Toolchain. Every example wo...
12 years agoI know it's an old topic, but the problem still exists in 13.0sp1.
I've followed your solution, adding the appropriate files to the environmental path. The nios2-download command is now found, but new errors return: /cygdrive/c/altera/13.0sp1/nios2eds/bin/nios2-download: line 2: $'\r': command not found. /cygdrive/c/altera/13.0sp1/nios2eds/bin/nios2-download: line 4: $'\r': command not found. /cygdrive/c/altera/13.0sp1/nios2eds/bin/nios2-download: line 15: $'\r': command not found. /cygdrive/c/altera/13.0sp1/nios2eds/bin/nios2-download: line 17: $'\r': command not found. /cygdrive/c/altera/13.0sp1/nios2eds/bin/nios2-download: line 23: $'\r': command not found. /cygdrive/c/altera/13.0sp1/nios2eds/bin/nios2-download: line 25: $'\r': syntax error near unexpected token '$'{\R'''cygdrive/c/altera/13.0sp1/sp1/nios2eds/bin/nios2-download: line 25: '{ nois2-terminal: connected to hardware target using JTAG UART on cable nois2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nois2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Now what :( this is so frustrating. I spend literally 12 hours not to get a demo working that was provided by altera. Shouldn't this be an out-of-the-box example?
