14 years agoDE0 Nano - Problem using the provided examples
Hi, i just received my DE0 Nano board and I've been trying the examples in the system CD. I've downloaded and installed Quartus 11.0sp1 + Nios II/Nios II GCC4 Toolchain. Every example wo...
14 years agotest_bashrc contains bash scripting syntax, while test.bat contains windows shell syntax.
You commented that you started from a windows cmd shell, and got dumped to a [NiosII EDS]$ prompt - which is the Cygwin prompt - so I was suggesting to start from the Cygwin prompt and see if that helped. Cheers, Dave
