10 years agoDE0-CV How to do "RUN" by EPCS64(POF file)
Hell, I bega to use a DE0-CV (P0192) board (5CB4F2C7N). I can programmed DE0_CV_Default.pof" to EPC64 on"PROG" mode by SW10 on the board. Demo execute "RUN" mode by SW10 on the board. ...
10 years agoThnks to your help.
I found configuration ROM is not EPCS64 in the DE0-CV circuit. DE0-CV User's Manual is wrriten with the EPCS64. However, it was S25FL064P on the board. I set "Disable EPCS ID check" on the Convert Programming File. ...Success!
