10 years agoDE0-CV How to do "RUN" by EPCS64(POF file)
Hell, I bega to use a DE0-CV (P0192) board (5CB4F2C7N). I can programmed DE0_CV_Default.pof" to EPC64 on"PROG" mode by SW10 on the board. Demo execute "RUN" mode by SW10 on the board. ...
10 years agoYou can start by checking your setting at Assignment--->Device--->device & Pin Options---> Configuration. Make sure they are the correct settings. Subsequently, try converting your sof file to pof file in the convert programming files. Make sure you choose the correct device. You can screenshot them so that we can help you to check if your settings are correct. Cheers :)
