LLian22
6 years agoDDR4 interface signal test abnormal
Hi: During the test of the DDR4 controller, we found that the data write DQ signal was abnormal, but the timing of the data read was normal and the data read was correct. The cause of the abnormal d...
BoonT_Intel
6 years agoHi are you using Arria 10 device.
See if it is impact by this issue-> https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/fb292783.html
You may try the suggested workaround.
