LLian22
6 years agoDDR4 interface signal test abnormal
Hi: During the test of the DDR4 controller, we found that the data write DQ signal was abnormal, but the timing of the data read was normal and the data read was correct. The cause of the abnormal d...
LLian22
6 years agoFor the current test, the interface timing calibration occasionally has a calibration failure, but recalibration after the failure can be passed. After the calibration is completed, the data read and write access test data can be transmitted normally, and there is no data error in the data verification. Only the oscilloscope observes the write timing is not normal
