12 years agoDDR3 A and DDR3 B - Cyclone V Dev Kit
Hi, I'm trying to deal with both DDR3 A and DDR3 B of the Cyclone V Dev Kit. Has anyone already tried to use both DDR3 A and B in the same design ? I met a problem to find out exact pins fo...
12 years agoHi,
look at the correct xls file to find rzq pins: http://www.altera.com/literature/lit-dp.jsp?category=cyc%205&showspreadsheet=y you can also display "all assignable pins" in the pin planner an then sort them by "special function". you will find rzq pins. if you have problems with calibration blocks look at: http://www.altera.com/support/kdb/solutions/rd02262013_81.html hope it helps.
