11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years agoI've started a new tutorial from scratch. I use Quartus II 13.1 and Modelsim ALTERA 10.1d. the "elab +nowarnTFMPC" gives:
elab +nowarnTFMPC# elab # vsim +nowarnTFMPC -L work -L work_lib -L altera_common_sv_packages -L rsp_xbar_mux -L rsp_xbar_demux -L cmd_xbar_mux -L cmd_xbar_demux -L limiter -L id_router -L addr_router -L led_pio_s1_translator_avalon_universal_slave_0_agent -L bfm_master_m0_translator_avalon_universal_master_0_agent -L led_pio_s1_translator -L bfm_master_m0_translator -L p2b_adapter -L b2p_adapter -L transacto -L p2b -L b2p -L fifo -L timing_adt -L jtag_phy_embedded_in_jtag_master -L rst_controller -L mm_interconnect_0 -L onchip_ram -L button_pio -L led_pio -L jtag_master -L bfm_master -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cycloneive_ver -t ps qsys_system # ** Error: Failure to obtain a Verilog simulation license. Unable to checkout any of these license features: alteramtivsim or alteramtivlog.# Error loading design
I'll see with my administrator for the license... With the ASE version I get: vlog -sv $TUTORIAL/hdl/qsys_system/test/qsys_system_bfm_master_tb.sv -L altera_common_sv_packages# Model Technology ModelSim ALTERA vlog 10.1d Compiler 2012.11 Nov 2 2012# -- Compiling module qsys_system_bfm_master_tb# -- Importing package altera_common_sv_packages.verbosity_pkg# -- Importing package altera_common_sv_packages.avalon_mm_pkg# # Top level modules:# qsys_system_bfm_master_tb
set TOP_LEVEL_NAME qsys_system_bfm_master_tb# qsys_system_bfm_master_tb
elab +nowarnTFMPC# elab # vsim +nowarnTFMPC -L work -L work_lib -L altera_common_sv_packages -L rsp_xbar_mux -L rsp_xbar_demux -L cmd_xbar_mux -L cmd_xbar_demux -L limiter -L id_router -L addr_router -L led_pio_s1_translator_avalon_universal_slave_0_agent -L bfm_master_m0_translator_avalon_universal_master_0_agent -L led_pio_s1_translator -L bfm_master_m0_translator -L p2b_adapter -L b2p_adapter -L transacto -L p2b -L b2p -L fifo -L timing_adt -L jtag_phy_embedded_in_jtag_master -L rst_controller -L mm_interconnect_0 -L onchip_ram -L button_pio -L led_pio -L jtag_master -L bfm_master -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cycloneive_ver -t ps qsys_system_bfm_master_tb # Loading sv_std.std# Loading altera_common_sv_packages.verbosity_pkg# Loading altera_common_sv_packages.avalon_mm_pkg# Loading work.qsys_system_bfm_master_tb# Loading work.qsys_system# Loading altera_common_sv_packages.avalon_utilities_pkg# Loading bfm_master.altera_avalon_mm_master_bfm# Loading jtag_master.qsys_system_jtag_master# Loading jtag_phy_embedded_in_jtag_master.altera_avalon_st_jtag_interface# Loading timing_adt.qsys_system_jtag_master_timing_adt# Loading limiter.altera_avalon_sc_fifo# Loading b2p.altera_avalon_st_bytes_to_packets# Loading p2b.altera_avalon_st_packets_to_bytes# Loading transacto.altera_avalon_packets_to_master# Loading b2p_adapter.qsys_system_jtag_master_b2p_adapter# Loading p2b_adapter.qsys_system_jtag_master_p2b_adapter# Loading rst_controller.altera_reset_controller# Loading led_pio.qsys_system_led_pio# Loading button_pio.qsys_system_button_pio# Loading onchip_ram.qsys_system_onchip_ram# Loading altera_mf_ver.altsyncram# Loading altera_mf_ver.ALTERA_DEVICE_FAMILIES# Loading altera_mf_ver.ALTERA_MF_MEMORY_INITIALIZATION# Loading mm_interconnect_0.qsys_system_mm_interconnect_0# Loading bfm_master_m0_translator.altera_merlin_master_translator# Loading led_pio_s1_translator.altera_merlin_slave_translator# Loading bfm_master_m0_translator_avalon_universal_master_0_agent.altera_merlin_master_agent# Loading led_pio_s1_translator_avalon_universal_slave_0_agent.altera_merlin_slave_agent# Loading led_pio_s1_translator_avalon_universal_slave_0_agent.altera_merlin_burst_uncompressor# Loading addr_router.qsys_system_mm_interconnect_0_addr_router# Loading addr_router.qsys_system_mm_interconnect_0_addr_router_default_decode# Loading id_router.qsys_system_mm_interconnect_0_id_router# Loading id_router.qsys_system_mm_interconnect_0_id_router_default_decode# Loading limiter.altera_merlin_traffic_limiter# Loading cmd_xbar_demux.qsys_system_mm_interconnect_0_cmd_xbar_demux# Loading cmd_xbar_mux.qsys_system_mm_interconnect_0_cmd_xbar_mux# Loading cmd_xbar_mux.altera_merlin_arbitrator# Loading cmd_xbar_mux.altera_merlin_arb_adder# Loading rsp_xbar_demux.qsys_system_mm_interconnect_0_rsp_xbar_demux# Loading rsp_xbar_mux.qsys_system_mm_interconnect_0_rsp_xbar_mux# Loading rsp_xbar_mux.altera_merlin_arbitrator# Loading rsp_xbar_mux.altera_merlin_arb_adder# Loading jtag_phy_embedded_in_jtag_master.altera_jtag_dc_streaming# Loading altera_mf_ver.altera_std_synchronizer# Loading jtag_phy_embedded_in_jtag_master.altera_jtag_streaming# Loading jtag_phy_embedded_in_jtag_master.altera_jtag_sld_node# Loading jtag_phy_embedded_in_jtag_master.altera_avalon_st_idle_remover# Loading jtag_phy_embedded_in_jtag_master.altera_avalon_st_idle_inserter# Loading jtag_phy_embedded_in_jtag_master.altera_avalon_st_clock_crosser# Loading jtag_phy_embedded_in_jtag_master.altera_jtag_src_crosser# Loading jtag_phy_embedded_in_jtag_master.altera_jtag_control_signal_crosser# Loading transacto.packets_to_master# Loading rst_controller.altera_reset_synchronizer# Loading jtag_phy_embedded_in_jtag_master.altera_avalon_st_pipeline_base# ** Warning: (vsim-8311) System Verilog assertions are supported only in Questasim.# # ** Error: (vsim-3063) C:/Users/rm231795/Documents/work/JTAG/cellule/quartus/jtag_to_avalon_mm_tutorial/hdl/qsys_system/test/qsys_system_bfm_master_tb.sv(86): Port 'led_export' not found in the connected module (3rd connection).# # Region: /qsys_system_bfm_master_tb/dut# ** Error: (vsim-3063) C:/Users/rm231795/Documents/work/JTAG/cellule/quartus/jtag_to_avalon_mm_tutorial/hdl/qsys_system/test/qsys_system_bfm_master_tb.sv(86): Port 'button_export' not found in the connected module (4th connection).# # Region: /qsys_system_bfm_master_tb/dut# ** Error: (vsim-3063) C:/Users/rm231795/Documents/work/JTAG/cellule/quartus/jtag_to_avalon_mm_tutorial/hdl/qsys_system/test/qsys_system_bfm_master_tb.sv(86): Port 'resetrequest_reset' not found in the connected module (5th connection).# # Region: /qsys_system_bfm_master_tb/dut# Error loading design
When trying to compile a simple verilog fulladder, Modelsim is ok. Isn't it showing a verilog license is available?
