APaci1
7 years agoCYCLONE5 SOC - Eth1 timing problems at 1 gbps
HI, I attempts to use my HPS Emac1 port in GMII, connected to micrel PHY. I have a running Angstrom distro, after boot it runs fine at 100 mbps only. At 1Gbps, it depends of compilation! I try many c...
APaci1
7 years agoHi Jumah! I connect the 125 Mhz generated from HPS in QSYS, exported to external Micrel PHY.
This design runs fine at 1 Gb only if I connect a Signal Tap to Ethernet wires (GMII mode) and the eth_gtx_clk. (!!!!)
If I disable STAP , design runs only at 100 Mbps....
So I think to timing issue.. I attempt to do all.. I assign fast registers to pin planner, eth_gtx_clock is defined as clock, with 125 Mhz timing and so on.. but nothing to do.
