Cosinus
6 years agoCyclone V SoC - Verify RX PHY clocks (Ethernet)
Hi
I am occupied with the baremetal ethernet implementation on a Cyclone V SoC DE10 nano board.
In the 'Cyclone V Hard Processor System Technical Reference Manual' (cv_5v4 2019.06.14) (chapter ‘...
EBERLAZARE_I_Intel
6 years agoHi,
May I know which Quartus version you are working on?.
Based on the document, firstly the Ethernet Controller must be in a reset state during static configuration, then the clock must be active and valid before the Ethernet Controller is brought out of reset.
- Cosinus6 years ago
I am using Quartus Prime 17.1.
But how can I verify if the PHY clocks are there? The manual just says "Bring the Ethernet PHY out of reset to verify that there are RX PHY clocks". The PHY was released from reset and all the configured clocks were setup.
Kind regards
Dan
- EBERLAZARE_I_Intel6 years ago
To verify the RX PHY clock, after bringing it out of reset, you can measure the rx_clk. The clock should be close to what you have configure in the settings.
