Cyclone V: reaching RGMII Data to Clock output skew of +/- 500ps
Hi Sheng,
Correct, even without the tracedelay (Combination 1), the setup fails.
"Could you try with PHY with delay option disabled, does the timing pass?"
But I do need the PHY-delay to shift the data from edge- to center-aligned. Without, timing will fail massivley.
...and did faild massively.
Again, what jitter at the Cyclone V is to be expected for such a combination of both, data and clk coming from ddio-buffer?
Could you please share with me what jitter is to expect.
Does the fpga maybe struggle to delay the data singals internally positive or negative to the clock signal?
Could I help the synthesis tool by shifting the external PHY-delay away from symmetric (2ns) towards a asymmetrical delay for example (+/- 1.5ns). But this is basically what I tried to achive before and failed.
