RHenr
6 years ago[Cyclone V HPS] Enable Transmit/Receive Checksum offload in Ethernet MAC
Hello, we are trying to enable Checksum Offload Engine (COE) / IPC Full Offload in our Cyclone V HPS. Here is what we have done so far: Use 32 bytes transmit/receive descriptors and set the ATD...
EBERLAZARE_I_Intel
6 years agoHi,
I apologize, I have checked from the Technical Reference Manual provided in my previous reply, the default bits are suppose that the Type 1 is by default is disabled and only Type 2 and the TX checksum is enabled.
Have you try a reset if this solves the issue? Just for confirmation can you share your kernel version that you are using?
I may need some more time to dig in for more information regarding this issue.
