11 years agoCyclone V GX Development Kit and PCIe
Hi, Is there a working example of a PCIe endpoint for the Cyclone V GX Development Kit? I can't find any reference design for this kit using the PCIe interface.. I tried to modify PCIe examples ...
11 years agoDid you ever find a solution to this? I am trying to get the same board up with little success. I have discovered that the pcie_perstn pin is not connected correctly in hardware. That probably caused your hanging. I moved it to the correct pin, but it still won't enumerate.
If I had an example that worked, then I would have some confidence that this demo board would work at all as designed. Thanks, Dan
