11 years agoCyclone V GT development Kit
Hi All! I've got my Cyclone V GT Development Kit and I have some difficulties with it. 1. Board Test System application fails when I try to launch it. 2. Where I can get some reference d...
10 years ago --- Quote Start --- can u try using sof2flash bts_config_13_0_0.sof to convert to the flash file that u need? This sof file is located in cycloneVGT_cgtfd9ef35_fpga/examples/board_test_system/bts_config folder. --- Quote End --- Hello, I'm a newbie in dealing with the Cyclone V GT development Kit. I started with the quick start guide, the explanations are very clear but when came the time to upload the bts_config.flash to my flash in this board, I was unable to locate this file in the stipulated folder (<installation directory>\kits\cycloneVGT_5cgtfd9ef35_fpga\factory_recovery\build_factory_source\) why this file is not present in the right folder (by default) ? Of course I tried to generate this file using sof2flash bts_.... as it was explained in the post the october 21, 2015 at 08:37 A.M I obtained a .flash file. The upload process with the BUP had worked pretty well. But when I opened the BTS the result was pretty bad (see below): http://www.alteraforum.com/forum/attachment.php?attachmentid=11727&stc=1 "NO USB BLASTER DETECTED" ! Do you know why? NB: I made the same test with Quartus15.1 standard edition, with Quartus13.0 and with the Quartus13.0sp1 (and in all cases did not work) Thanks for any comments, remarks or ideas to fix this problem. B.R Yan,
