Cyclone V GT Dev Kit - new units fail to boot from FPP
- 1 month ago
An update/fix if someone else encounters the same issue.
GordWait an I kept investigating the problem and sharing our findings daily, until we got all our boards working 100% of the time on hundreds of reboots. While we ended up with slightly different solutions the root cause is the same, and I will share the core of what helped me for future reference.The root of the problem is presumably some signal integrity/timing issue across the fpga_config_d/fpga_dclk lines, which seems to be present only on newer boards/chips.
The greatest improvement came from reducing the drive strength of these lines, by adding in the QSF:
set_instance_assignment -name CURRENT_STRENGTH_NEW 7MA -to fpga_dclk
set_instance_assignment -name CURRENT_STRENGTH_NEW 7MA -to fpga_config_d[*]While this solution helped on most of the affected boards it did not fix them all.
To better improve the situation the fpga_dclk can be effectively reduced to 50 MHz, with the easiest way being changing the pfl_x8_inst's "Ratio between input clock and DCLK output" to 2. By doing this the fpga_config_d changes on the fpga_dclk's falling edge, thus improving the hold slack.
To better suit this fix there are some constraints to add in the .sdc.
- fpga_dclk should be a generated one:
create_generated_clock -name {fpga_dclk} -source {clk_config} -divide_by 2 [get_ports {fpga_dclk}]- The data output delay should be based on this clock and respect the Cyclone V datasheet tsu:
set_output_delay -add_delay -max -clock [get_clocks {fpga_dclk}] 5.500 [get_ports {fpga_config_d[*]}]
set_output_delay -add_delay -min -clock [get_clocks {fpga_dclk}] -1.000 [get_ports {fpga_config_d[*]}]- If using the "Ratio" option a multicycle path should actually be defined:
set_multicycle_path -setup -start 1 -from [get_registers {*|alt_pfl_cfg_fpga:*|fpga_data_reg[*]}] -to [get_ports {fpga_config_d[*]}]
set_multicycle_path -hold -start 1 -from [get_registers {*|alt_pfl_cfg_fpga:*|fpga_data_reg[*]}] -to [get_ports {fpga_config_d[*]}]Note that these fixes don't consider the usage of the FPPovJ, for which better constrains should be designed.
Moreover, the FPP boot time is largely limited by the flash access time, so even halving the DCLK won't affect the boot time much. Even with the 50 MHz clock it still boots comfortably within our system's PCIE enumeration window.All of this was tested on a limited number of boards, so I can't assure this works 100% of the time, but until Altera finds a proper solution this can be a good starting point for anyone facing the same problem as we did.
Leonardo
Leonardo
