DimaBA
5 years agoCyclone V GND pins
In one of our projects, which used 5CGXFC5F6M11I7N (Cyclone V) during the layout had been done mistake. How affected on FPGA if up to 4 GND balls are not connected?
DimaBA
5 years agoHello.
No, the FPGA doesn't show any abnormal behavior.
Before I give waiver for next PCB assemblies, I just want be sure that won't be any issues with FPGA.
Attached2 of 4 problem pads
AminT_Intel
5 years agoHello,
It seems like your FPGA is working fine. Sometimes FPGA can be damaged over long-term period like example when you set the voltage out of specs.
Thank you.
