cyclone v flashing issue with EPCQ256 and QSPI
Hi, I am using cyclone v device(5CSEMA4U23A7).
I am trying two methods for flash.
1) When i am trying to flash using EPCQ256N(EPCQ256SI16N) i am getting below error:
Procedure followed to flash
Active Serial Configuration via JTAG - YouTube
Info (209060): Started Programmer operation at Fri Sep 07 11:49:45 2018
Info (209016): Configuring device index 2
Info (209017): Device 2 contains JTAG ID code 0x02D020DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Fri Sep 07 11:49:47 2018
Info (210033): Memory Map File output_files/output_file.map contains memory usage information for file output_files/output_file.jic
Info (209060): Started Programmer operation at Fri Sep 07 11:50:48 2018
Info (209018): Device 2 silicon ID is 0x19
Info (209044): Erasing ASP configuration device(s)
Info (209023): Programming device(s)
Info (209061): Ended Programmer operation at Fri Sep 07 11:52:38 2018
Info (209060): Started Programmer operation at Fri Sep 07 11:58:38 2018
Error (209015): Can't configure device. Expected JTAG ID code 0x02D020DD for device 2, but found JTAG ID code 0x02D010DD. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Fri Sep 07 11:58:38 2018
Info (209060): Started Programmer operation at Fri Sep 07 11:59:05 2018
Info (209017): Device 2 contains JTAG ID code 0x02D010DD
Error (209025): Can't recognize silicon ID for device 2. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly.
Info (209061): Ended Programmer operation at Fri Sep 07 11:59:14 2018
Info (210098): Active Serial/Parallel mode CONF_DONE pin error check is disabled
Info (209060): Started Programmer operation at Fri Sep 07 12:06:28 2018
Info (209061): Ended Programmer operation at Fri Sep 07 12:06:37 2018
2) When i am trying to flash using QSPI(MT25QL512ABB8ESF) i am getting below error observed in serial port:
I am using FPPx16 MSEL settings for loading FPGA from HPS.
https://rocketboards.org/foswiki/Documentation/GSRD131ProgrammingFPGA
U-Boot SPL 2013.01.01 (Sep 12 2018 - 16:22:55)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 700 MHz
CLOCK: DDR clock 80 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 50000 KHz
CLOCK: QSPI clock 350000 KHz
RESET: COLD
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 1024 MiB
FPGA : Programming FPGA
SF: Read data capture delay calibrated to 3 (0 - 6)
SF: Detected N25Q512 with page size 65536, total: 67108864
FPGA: Poll CD failed with error code -4
### ERROR ### Please RESET the board ###
U-Boot SPL 2013.01.01 (Sep 10 2018 - 16:44:48)
RESET: COLD
SDRAM: 1024 MiB
FPGA: Poll usermode failed with error code -8
1 Reply
- ShafiqY_Intel
For your 1st EPCQ256N error:
Usually for Error (209025) problem can be cause by one or more of following condition:
- MSEL pins are not set for Active Serial (AS) configuration.
- Communications cable(s) not securely connected.
- Incorrect device selected.
- No power to target system.
- Device pins connected incorrectly.
- Driving the flash interface pins with another device.
- Undefined devices in the JTAG chain.
My advice to you is make sure that MSEL pins are set for Active Serial (AS) configuration and select the device correctly.
For your 2nd error:
Make sure your MSEL pins are set correctly. And try to use non-compression configuration file (MSEL[4..0]=00000)
Thank you.
