JZeng17
7 years agoCyclone V DMA IP convert Axi burst to Axi stream
Hi, i was wondering if intel fpga has a IP that can convert Axi burst to Axi stream like dma ip in xilinx, i'm using a de10-nano to build my system, i'm using the cpu(a9) to send data from hps to fpga through bridge, but the interface on my IP is using axi stream protocal. So is there a way that i can switch a memory map data burst to a steam like burst?
- EBERLAZARE_I_Intel
I apologize that I may have been confused with the question, are you trying to send data without bursting?
Do you have any followup from your side?
Regards.
