nhgeordie
5 years agoCyclone V dev kit power connector J22 size?
I want to make a pigtail with a USB controlled relay to remotely power cycle the dev kit. For various reasons the company does not support working with the hardware at home. I also can't easily use a...
- 5 years ago
Hello
Welcome to INTEL forum. You should be able to find the Cyclone V dev kit power connector J22 size from dev kit BOM list and you can find the datasheet for this J22 connector based on the part number. Example below is the BOM list path from dev kit installer
• \ cycloneVSX_5csxfc6df31_soc\board_design_files\ cycloneVSX_5csxfc6df31_soc\bom
AR_A_Intel
5 years agoSounds good, hope everything is working well at your side. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
