Cyclone V dev kit power connector J22 size?
- 5 years ago
Hello
Welcome to INTEL forum. You should be able to find the Cyclone V dev kit power connector J22 size from dev kit BOM list and you can find the datasheet for this J22 connector based on the part number. Example below is the BOM list path from dev kit installer
• \ cycloneVSX_5csxfc6df31_soc\board_design_files\ cycloneVSX_5csxfc6df31_soc\bom
Hello
- nhgeordie5 years ago
Ah, thank you. As a software engineer I seldom think about the BOM.
For anyone else who wonders, 5.5mm outside diameter, 2.5mm inside. The line from the BOM is
P23-35030R, 1, J22, Switchcraft Inc., RAPC712X, CONN - JACK PWR RAPC712
The PSU has various connectors available, but all use 9mm length. So I need a 9mm long 5.5 OD, 2.5 ID barrel connector.
