Cyclone V 5CEFA2F23C8N stuck in configuration error loop.
Hi HQuan3,
I suspect it might be the minimum Data Hold time (tDH) timing specification for Active Serial (AS) configuration issue.
I checked your Cyclone V OPN (5CEFA2F23C8N), and it was listed as the affected OPNs:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/pcn/adv1831-opn-list.xlsx
You may refer to the following CUSTOMER ADVISORY (ADV1831) for more details.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/pcn/adv1831.pdf
- HQuan37 years ago
Hi Wolfgang,
Thank you for your reply.
What I see from ADV1831 is that the data hold time requirement has gotten smaller, which is normally a good thing. But that document references another document, which I will need to dig into.
New development:
What I have observed in probing the configuration phase further is that I am getting an error because CRC does not pass. CRC does not pass because the FPGA ignores the first four bits of read data during a Fast Read command. Therefore all read data is shifted by a nibble, which is obviously wrong. THe FPGA performs the CRC check and fairly immediately restarts.
My guess is that the original jic file, which was targeting the Micron N25Q032A13ESE40G NOR flash, has a different dummy cycle setting from the new EPCQ32A part. In the EPCQ32A spec, I don't see a way of changing the number of dummy read cycles.
I don't have the luxury of the .sof file, so I seem out of luck with generating a new jic that targets the EPCQ32A. Any possible workarounds for that?
- ShafiqY_Intel7 years ago
Hi HQuan3,
I dont think you can change the dummy clock for EPCQ-A device.
In your current .jic file, which configuration device that was selected? (i.e epcq, epcs)
May I know which programming IP did you used for this design?
- HQuan36 years ago
Hi Wolfgang,
Sorry for the delay, I am in jury duty for the next month.
--Right, there is no way to change the Intel EPCQ-A dummy cycles.
--In the current .jic file it shows EPCQ when I add it to the Quartus Prime Programmer Lite utility.
I have also discovered that when switching back to the old Micron part, everything works just fine again. But as this part is EOL, I still don't have a long term solution.
