Cyclone V - Differential Pair Pin Assignment 1.5V PCML fitter error
- 4 years ago
Hi Terra,
I have told you earlier, you cannot directly connect, Please design custom logic to reconstruct the word. First correct your design then try to compile.
Thank you
Kshitij Goel
Still trying to instantiate the "SDI II Intel FPGA IP" core. I tried creating another PLL. This time with the "Fractional" option to output the 74.25MHz signal.
I am still getting a Fitter Error.
Info (184020): Starting Fitter periphery placement operations
Error (14996): The Fitter failed to find a legal placement for all periphery components
Info (14987): The following components had the most difficulty being legally placed:
Info (175029): fractional PLL intel_fract_PLL_50:XCVR_PLL_2|intel_fract_PLL_50_0002:intel_fract_pll_50_inst|altera_pll:altera_pll_i|general[0].gpll~FRACTIONAL_PLL (100%)
Error (14986): After placing as many components as possible, the following errors remain:
Error (175001): The Fitter cannot place 1 global or regional clock driver, which is within PLL Intel FPGA IP intel_fract_PLL_50.
Info (14596): Information about the failing component(s):
Info (175028): The global or regional clock driver name(s): intel_fract_PLL_50:XCVR_PLL_2|intel_fract_PLL_50_0002:intel_fract_pll_50_inst|altera_pll:altera_pll_i|outclk_wire[0]~CLKENA0
Error (16234): No legal location could be found out of 46 considered location(s). Reasons why each location could not be used are summarized below:
Error (15123): The following global or regional clock driver locations cannot route to all the required HSSI TX PLD PCS Interfaces
Info (175027): Destination: HSSI TX PLD PCS Interface SDI_XCVR:SDI_ii_Bidirectional1|SDI_XCVR_0002:sdi_xcvr_inst|altera_xcvr_native_av:u_phy|av_xcvr_native:gen_native_inst.av_xcvr_native_insts[0].gen_bonded_group_native.av_xcvr_native_inst|av_pcs:inst_av_pcs|av_pcs_ch:ch[0].inst_av_pcs_ch|av_hssi_tx_pld_pcs_interface_rbc:inst_av_hssi_tx_pld_pcs_interface|wys
Info (175029): 16 locations affected
Info (175029): CLKCTRL_R82
Info (175029): CLKCTRL_R83
Info (175029): CLKCTRL_R84
Info (175029): CLKCTRL_R85
Info (175029): CLKCTRL_R86
Info (175029): CLKCTRL_R87
Info (175029): CLKCTRL_R10
Info (175029): CLKCTRL_R11
Info (175029): CLKCTRL_R12
Info (175029): CLKCTRL_R13
Info (175029): CLKCTRL_R14
Info (175029): CLKCTRL_R15
Info (175029): and 4 more locations not displayed
Info (175013): The global or regional clock driver is constrained to the region (0,
Info (175015): The I/O pad CLOCK_50_B7A is constrained to the location PIN_H12 due to: User Location Constraints (PIN_H12)
Info (14709): The constrained I/O pad is contained within a pin, which drives a fractional PLL, which drives a PLL output counter, which drives this global or regional clock driver
Error (175007): Could not find uncongested path between source PLL output counter and the global or regional clock driver
Info (175026): Source: PLL output counter intel_fract_PLL_50:XCVR_PLL_2|intel_fract_PLL_50_0002:intel_fract_pll_50_inst|altera_pll:altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER
Info (175013): The PLL output counter is constrained to the region (0, 17) to (0, 33) due to related logic
Info (14709): The constrained I/O pad is contained within a pin, which drives a fractional PLL, which drives this PLL output counter
Info (175021): The PLL output counter was placed in location PLLOUTPUTCOUNTER_X0_Y29_N1
Error (175022): The global or regional clock driver could not be placed in any location to satisfy its connectivity requirements
Info (175029): 30 locations affected
Info (175029): CLKCTRL_G0
Info (175029): CLKCTRL_G1
Info (175029): CLKCTRL_G2
Info (175029): CLKCTRL_G3
Info (175029): CLKCTRL_R64
Info (175029): CLKCTRL_R65
Info (175029): CLKCTRL_R66
Info (175029): CLKCTRL_R67
Info (175029): CLKCTRL_R68
Info (175029): CLKCTRL_R69
Info (175029): CLKCTRL_R40
Info (175029): CLKCTRL_R41
Info (175029): and 18 more locations not displayed
Info (184021): Fitter periphery placement operations ending: elapsed time is 00:00:00
