Cyclone V - Differential Pair Pin Assignment 1.5V PCML fitter error
- 4 years ago
Hi Terra,
I have told you earlier, you cannot directly connect, Please design custom logic to reconstruct the word. First correct your design then try to compile.
Thank you
Kshitij Goel
I tried to add SDI_v16.1 as a generate Transceiver only Bidirectional IP Core. Then I added a Altera PLL and created an output clock of 74.25MHz.
I have Quartus setup to add the generated files to the Project automatically, but it doesn't seem to compile.
The Compile errors I am getting now are:
- Info (12021): Found 1 design units, including 1 entities, in source file sdi-library/sdi_rate_detector.v
Info (12023): Found entity 1: sdi_rate_detector
Info (12128): Elaborating entity "sdi_rate_detector" for hierarchy "SDI_v16_t:SDI_v16_Bidirectional1|sdi_megacore_top:sdi_megacore_top_inst|sdi_txrx_port:sdi_txrx_port_gen[0].u_txrx_port|sdi_rate_detector:sdi_receiver_rate_detector.rate_detector_inst"
Error (12006): Node instance "gen_duplex_native.cv_nativephy_inst" instantiates undefined entity "altera_xcvr_native_av". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "gen_duplex_native.tx_xcvr_reset_control_inst" instantiates undefined entity "altera_xcvr_reset_control". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "gen_duplex_native.rx_xcvr_reset_control_inst" instantiates undefined entity "altera_xcvr_reset_control". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 3 errors, 30 warnings
Error: Peak virtual memory: 4795 megabytes
Error: Processing ended: Tue Jul 19 19:00:45 2022
Error: Elapsed time: 00:00:10
Error: Total CPU time (on all processors): 00:00:19
Error (293001): Quartus Prime Full Compilation was unsuccessful. 5 errors, 30 warnings
The code from my top.v file is:
module C5G_HSMC_XCVR_LOOPBACK_TEST(
///////// ADC /////////
output ADC_CONVST,
output ADC_SCK,
output ADC_SDI,
input ADC_SDO,
///////// AUD /////////
input AUD_ADCDAT,
inout AUD_ADCLRCK,
inout AUD_BCLK,
output AUD_DACDAT,
inout AUD_DACLRCK,
output AUD_XCK,
///////// CLOCK /////////
input CLOCK_125_p,
input CLOCK_50_B5B,
input CLOCK_50_B6A,
input CLOCK_50_B7A,
input CLOCK_50_B8A,
///////// CPU /////////
input CPU_RESET_n,
///////// GPIO /////////
inout [35:0] GPIO,
///////// HDMI /////////
output HDMI_TX_CLK,
output [23:0] HDMI_TX_D,
output HDMI_TX_DE,
output HDMI_TX_HS,
input HDMI_TX_INT,
output HDMI_TX_VS,
///////// HEX0 /////////
output [6:0] HEX0,
///////// HEX1 /////////
output [6:0] HEX1,
///////// HSMC /////////
input HSMC_CLKIN0,
input [2:1] HSMC_CLKIN_n,
input [2:1] HSMC_CLKIN_p,
output HSMC_CLKOUT0,
output [2:1] HSMC_CLKOUT_n,
output [2:1] HSMC_CLKOUT_p,
inout [3:0] HSMC_D,
input [0:0] HSMC_GXB_RX_p,
output [0:0] HSMC_GXB_TX_p,
output HSMC_SDI_Rate_Sel_1,
output HSMC_SDI_Rate_Sel_2,
output HSMC_EQBypass_1,
output HSMC_EQBypass_2,
output HSMC_SDI_CLK_Sel,
output HSMC_SDI_XTAL_Sel,
///////// I2C /////////
output I2C_SCL,
inout I2C_SDA,
///////// KEY /////////
input [3:0] KEY,
///////// LEDG /////////
output [7:0] LEDG,
///////// LEDR /////////
output [9:0] LEDR,
///////// SD /////////
output SD_CLK,
inout SD_CMD,
inout [3:0] SD_DAT,
///////// SRAM /////////
output [17:0] SRAM_A,
output SRAM_CE_n,
inout [15:0] SRAM_D,
output SRAM_LB_n,
output SRAM_OE_n,
output SRAM_UB_n,
output SRAM_WE_n,
///////// SW /////////
input [9:0] SW,
///////// UART /////////
input UART_RX,
output UART_TX
// REG/WIRE declarations
wire reset_hsmc_xcvr_phy;
wire reset_xcvr_reconfig;
wire [19:0] SDI_Databus20;
wire TRS_First_Word;
wire TRS_Locked = 1'b1;
wire [10:0] Line_Number;
wire CLOCK_148_5MHZ;
wire CLOCK_74_25MHZ;
wire reset1_n;
wire reset2_n;
wire reset_n;
//-----HSMC Daughter Card support
reg SDI_Rate_Sel_1 = 1'b0;
reg SDI_Rate_Sel_2 = 1'b0;
reg EQBypass_1 = 1'b0;
reg EQBypass_2 = 1'b0;
reg SDI_CLK_Sel = 1'b0;
reg SDI_XTAL_Sel = 1'b0;
// assignments
assign HSMC_EQBypass_1 = EQBypass_1; // RX Cable Equalizer. High = Bypass, Low = Use equalizer.
assign HSMC_EQBypass_2 = EQBypass_2; // RX Cable Equalizer. High = Bypass, Low = Use equalizer.
assign HSMC_SDI_Rate_Sel_1 = SDI_Rate_Sel_1; // TX Cable Driver. High = SD, Low = HD/3G
assign HSMC_SDI_Rate_Sel_2 = SDI_Rate_Sel_2; // TX Cable Driver. High = SD, Low = HD/3G
assign HSMC_SDI_CLK_Sel = SDI_CLK_Sel;
assign HSMC_SDI_XTAL_Sel = SDI_XTAL_Sel;
PLL_XCVR XCVR_PLL_1 (
.refclk(CLOCK_50_B7A), // refclk.clk
.rst(~CPU_RESET_n), // reset.reset
.outclk_0(CLOCK_148_5MHZ), // outclk0.clk
.outclk_1(CLOCK_74_25MHZ), // outclk1.clk
.locked(reset_n) // locked.export
//---Generated SDI v16.1 IP CORE. Bidirectional. No Protocol block (Transceiver Only).
SDI_v16_t SDI_v16_Bidirectional1 (
.rst_rx ( ~reset_n ),
.rst_tx ( ~reset_n ),
.rx_serial_refclk ( CLOCK_74_25MHZ ), // input must be nominally 1/20th of the serial data rate. This clock trains the internal PLL.
.tx_pclk ( CLOCK_74_25MHZ ),
.tx_serial_refclk ( CLOCK_74_25MHZ ),
.sdi_rx ( HSMC_GXB_RX_p ), // Pin#
.txdata ( SDI_Databus20 ), // input [19:0] 20bits to HD-SDI
.refclk_rate ( 1'b1 ), // Set input to 1 for 148.5-MHz RX serial reference clock, to 0 for a 148.35-MHz receiver serial reference clock.
.rx_protocol_locked ( TRS_Locked ), // input
.rx_xcvr_trs_lock ( TRS_Locked ), // input stays high when valid TRS packets are detected.
.sdi_reconfig_togxb ( ),
.sdi_tx ( HSMC_GXB_TX_p ), // Pin#
.rxdata ( SDI_Databus20 ), // output [19:0] 20bits from HD-SDI
.rx_data_valid_out ( ),
.rx_clk ( CLOCK_74_25MHZ ), // input
.rx_status ( ),
.tx_status ( ),
.detected_rate ( ),
.gxb_tx_clkout ( ),
.sdi_reconfig_fromgxb ( )
endmodule
