11 years agoCyclone IV Transciever Starter Kit Automation Issue MAX_error LED stuck on.
We have an automated test system running with Cyclone IV Transciever Cards acting as PCIe EP's. Our automation system load the .elf to the card memory via a NIOS console running on a host PC. ...
11 years agoHi Dave,
This seems un-scientific ... I tried to re-produce the result seen before lunch with the automation folks and was not able to reproduce the result. ie no red MAX_EROR LED. Does that mean the Cyclone card was in some state that when the nios2-terminal was connected and the card power cycled caused the MAX_ERROR LED to come on ... Just 1/2 an hour ago I saw another Cyclone card locked up with the MAX_ERROR LED stuck on and in that case the NIOS Eclipse GUI was active not a NIOS Command terminal ... so I agree I need to work some more to get to root cause ... all I can say was that ... whatever I did in my office environment ... I got to a matching behavior as seen in an automation environment. Let me gather some more info on this and modify the status to .... "trending to solved ....." Thanks, Bob.
