11 years agoCyclone IV Transciever Starter Kit Automation Issue MAX_error LED stuck on.
We have an automated test system running with Cyclone IV Transciever Cards acting as PCIe EP's. Our automation system load the .elf to the card memory via a NIOS console running on a host PC. ...
11 years agoDave and others,
I have attached some NIOS Command Window results in the hang state and not hang state. Here is the output. Issuing nios2 flash command: "C:\altera\13.1\nios2eds\Nios II Command Shell.bat" nios2-download -r -g > %TEMP%\nios2-download.txt there are no nios ii cpus with debug modules available which match the valuesspecified. please check that your pld is correctly configured, downloading a
new sof file if necessary. This kind of tells me that the FPGA did not load successfully after a power cycle of the system. I tried pressing the PGM_CONF in the error state and the error LED goes off then on again. I have a log of automation results and apparently a card that is hung with the Error LED on had just previously passed, indicating the main thing was probably a power cycle ... Now I am wondering if somehow the USB "connection was possibly active from the PC to the USB controller on the Cyclone card , when the Cyclone card was re-cycled via the PCIe slot power being cycled off then on ... In this case, the USB controller didn't get a power cycle since it is held up via the USB +5VDC from the host PC . I will try that experiment to see if I get the same behavior . Thanks, Bob.
