SAnan1
7 years agoCyclone IV GX Transceiver starter kit pin_planner disagrees with documentation
-------------------------------------------------------- Image 1 : clock_pins_cycloneivgx -------------------------------------------------------- Pin A9,A10 : clock Pin F12,F13 : clock pin G...
CheepinC_altera
7 years agoHi,
As I understand it, you are observing some pin function mismatch between the pin planner vs the reference manual of the CIV GX starter devkit. From pin planner you are observing some pins as clock but in the manual, they have other functionality. Would you mind to help cross-checking with the devkit schematic on these pins to see if it matches the manual or pin planner.
Thank you very much.
Chee Pin
