14 years agoCyclone IV GX starter Kit - PCIe
Hi, I am trying to test the PCIe on the Cyclone IV GX starter kit, I am using the standard chaining DMA example. I have configured the PCIe as Endpoint with x1. I am able to see the Device in t...
14 years agoBefore guiding you through the proper decoding of the BAR indication for received packets, I would question that you need two different BARs of equal kind for your different function’s tasks. Just split your BAR address range, say, the address range from 0x0000 to 0x0FFF is used for your first logic, then from 0x1000 to 0x1FFF for your second logic. You just have to decode the appropriate address wire. And your driver won’t mind either.
