13 years agoCyclone IV GX FPGA Development Kit Power Supply. Why so sophisticated?
Why Power Supply on "Cyclone IV GX FPGA Development Kit" is so sophisticated? Why not use simple 3-pin LDO instead of multi-pin Linear Regulators used on this Kit? A picture from "Cyclone IV GX ...
13 years ago --- Quote Start --- Why Power Supply on "Cyclone IV GX FPGA Development Kit" is so sophisticated? --- Quote End --- What do you consider it sophisticated? The Pin Connection Guidelines for each FPGA describes how Altera recommends powering the FPGA. Multiple linear regulators are required to generate and/or isolate the required voltages. --- Quote Start --- Why not use simple 3-pin LDO instead of multi-pin Linear Regulators used on this Kit? --- Quote End --- FPGAs have a power-on requirement that the power rails ramp in a well-defined time period. Multi-pin linear regulators generally have enable and soft-start functions that can be used to aid in power-on sequencing. A simple 3-pin linear regulator does not provide this functionality. Cheers, Dave
