12 years agoCyclone IV GX FPGA Development board not recognised by PC when in PCIe slot
Just received a Cyclone IV GX FPGA Development kit and downloaded the demo c4gx_PCIe_gen1_x1.sof to it but when the PC boots up id does not recognise the board. I am unable to install a driver for it...
12 years ago --- Quote Start --- Tried the Linux command lspci and nothing was listed. The alive LED on the pcie board is flashing so I assume that the board is working. I have now tried another demo this time using a c4gx_qsys_ocie_gen1x4.sof file. --- Quote End --- Ok, those steps all sound reasonable. --- Quote Start --- The PC I am using is a HP I will try a Dell to see if it works in that, just wondering if it is a speed issue or something to do with the pcie slot or something. --- Quote End --- That sounds like a good idea. If that fails to work, then you could add a SignalTap II instance to the PCIe example design, and trace the state of the PCIe interface. Cheers, Dave
