14 years agoCyclone IV GX dev kit HSMC connection buned MAXII BGA chip
Hi all, I have a serious question here. Please spend some time to read through my explanation below as I really need some help! I appreciate your time very much. Previously I used the Cycl...
14 years ago --- Quote Start --- The most plausible explanation for getting "smoke" on the daughter board is that you inadvertently connected to a 12V-pin of the HSMC connector. You should check all pins in the vicinity of the 12V node for possible shorts. --- Quote End --- Smoke is seen on the host board MAXII CPLD, not daughter board. The host board is the Cyclone IV GX dev kit. I have triple checked the 12V and GND pins. They are not shorted and are matched on the correct pins.
