14 years agoCyclone IV GX dev kit HSMC connection buned MAXII BGA chip
Hi all, I have a serious question here. Please spend some time to read through my explanation below as I really need some help! I appreciate your time very much. Previously I used the Cycl...
14 years ago --- Quote Start --- Last time before I used CIVGX board, I tested and run the same design on CIII Starter board too. Through the HSMC, I give 3.3V input signal and it is still functioning well. So I have no idea why it is not functioning in CIVGX. --- Quote End --- Sorry to be blunt but I don't care what you escaped without destroying before you broke the CIVGX. The Cyclone IV data sheet in I/O Stardard Specifications, Table 1-15 in the version I have, says VinHigh Max for a 2.5V IO is Vcc+0.3V, ie 2.8V. If you're driving anything higher in you're asking for trouble (unless you add properly calculated current limiting resistors). --- Quote Start --- Also, I find the MAXII device does not connect to HSMC pins. Attached the MAXII block diagram from the C4GX reference manual. Pls advice if I understand the block diagram wrongly. Thank you. --- Quote End --- There isn't enough detail in that to diagnose the problem, try to get hold of the schematics and trace all the HSMC connections. Nial
