14 years agoCyclone IV GX dev kit HSMC connection buned MAXII BGA chip
Hi all, I have a serious question here. Please spend some time to read through my explanation below as I really need some help! I appreciate your time very much. Previously I used the Cycl...
14 years ago --- Quote Start --- I'm not sure about the CIV board but the CIII started board has 2.5V IO with no protection on the inputs so I'd wouldn't expect the inputs to reliably work / survive with 3.3V. If the Max device can see the HSMC pins it might be that it's got 2.5V IO and can't withstand 3.3V. Nial. --- Quote End --- Last time before I used CIVGX board, I tested and run the same design on CIII Starter board too. Through the HSMC, I give 3.3V input signal and it is still functioning well. So I have no idea why it is not functioning in CIVGX. Also, I find the MAXII device does not connect to HSMC pins. Attached the MAXII block diagram from the C4GX reference manual. Pls advice if I understand the block diagram wrongly. Thank you.
