14 years agoCyclone IV GX dev kit HSMC connection buned MAXII BGA chip
Hi all, I have a serious question here. Please spend some time to read through my explanation below as I really need some help! I appreciate your time very much. Previously I used the Cycl...
14 years agoHI, according to the Cyclone IV GX reference manual (p.38 under HSMC subtitle), it says "The HSMC port A interface has programmable bi-directional I/O pins that can be used as 2.5-V LVCMOS, which is 3.3-V LVTTL-compatible."
With that, is 3.3V permitted as input signal for HSMC Port A? Or only max up to 2.5V is accepted? If I supply 3.3V as input signal voltage to HSMC Port A, is there the possibility that it causes the MAXII to burn?
