14 years agoCyclone IV development kit , SRam and Flash under qsys
I work on the Cyclone IV GX FPGA Development kit, i build a system on Qsys, with Nios II, tri_state_bridge, cfi flash and SSRAM. But i don't find the good SSRAM controller, it isnot the same interface with the kit doc ( ssram_ban,ssram_bbn,ssram_clk,ssram_e1n..). the SSRAM is GSI GS832018GT-200V. thanks a lot3 Replies
I have the same problem. Maybe the cypress driver could work. Have you tested it ?
I will try a mem_test to be sure. - Altera_Forum
In the example kit ( "board_update_portal" example), this example uses for the ssram controller a generic tri-state controller , the same for the Flash.
This example permits to read and write ot the SSRAM and Flash. That give a good example but in verilog . I work in vhdl :( - Altera_Forum
I use the "ssram16_hw.tcl" file with sopc and it works. just copy the folder "ip" in your project.
after installing the kit installations files, you will find it file in: \altera\11.0\kits\cycloneIVGX_4cgx150_fpga\examples\board_test_system\bts_config\ip\ssram16
