17 years agoCyclone III StarterKit EP3C25F324C6 DDR-Problem
Hi everyone, i have a problem with a small example configuration of a Nios II System using DDR. I use quartus 8.1 full license. I get fitting errors which tell me the following: -----------------...
17 years agoIf you still have problems another approach may be to open an example design that already uses the DDR (e.g. the nios example in the starter kit pack) and then modify it to your needs.
